I have an .avi file that plays fine on the computer but when I try to convert it to mpeg, I get the error message. The avi file is MPEG-1 576x320 23.976fps CBR 1150kbps, Layer-2 48000Hz 192kbps.I am using the vcd ntsc template to convert it to Video-CD NTSC (MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 224kbps). This is when I get the error occured when audio is decoded message. If I try decoding it as above but leave the audio at the original 48000 x 192 it records fine but I get no sound at all.Any help would be greatly appreciated.
TMPEGEnc has problems with 48Khz audio as you mentioned you have wmoser
I found that using an external audio encoder (which Tmpegenc) fully supports
I recomend using SCMPX
http://www.70.nu/ch3/index_e.html
this supports full MPEG audio encoding as also frequency conversion. Which will solve this problem of yours.
AVCHD - Converting video pass 1: Errorcode: 0x0401,Error occured
By time2innov8 in forum Authoring (Blu-ray)Replies: 10Last Post: 19th Jan 2014, 14:20 -
Error -1856: An Unknown error occured
By Tyler2000 in forum Software PlayingReplies: 2Last Post: 27th Oct 2010, 19:55 -
Invalid audio bitrate error on TMPGEnc Authoring Works 4
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 12th Jun 2010, 23:13 -
Blocking artifacts in H.264 decoded video
By gabbasb in forum ProgrammingReplies: 0Last Post: 18th May 2010, 04:44 -
Sound is not decoded properly using the latest Quickplay v3.7
By pwangdel in forum Software PlayingReplies: 0Last Post: 8th Nov 2008, 09:38
