    Long Island
    Need help... bought a fuji finpix s602 dig camera which does video. It creates avi (mjpeg) 30 fps at 640X480 res. Quicktime was the software supplied with the camera. The avi can only be played via quicktime. I assume I need an encoder or codex for TMPGEnc to work. My DVD player does vcd and xvcd only. Questions are, what's the best way to encode to mpeg for vcd/xvcd TMPGEnc ? Can I keep 640x480 res, with an xvcd ? Any advice would be great.
    tks
    lg
    Apr 2002
    The State of Frustration
    There are sveral templates available for use in TMPGEnc for XVCDs. If you check under VCD at left, you will find your resolution will be either 702 x 480, or 352 x 480. Try these templates from here:
    Kwag
    Hello.
