Hi
I have DivX movies with AC3 sound and convert them to SVCD movies, with subtitles. I'm using VirtualDub as Frame Server, and covert the movie with the program TMPGEnc_Plus. I'm also using Nero to burn the file to CD. So far so good.
The problem I have is with the sound.
I Would like to know how to convert the sound from AC3 to MPEG-2 Multi-Channel 5.1 surround audio. Is it possible? I belive it is, but propably I'm not using the correct program. I have tried a couple of them without success. I'm able to receive 2 channel sound, so I'm NOT intrested for a solution regarding 2 channel stereo.
Regards /TETRIS
I think you can apply these surround programs on a WAV file, huh... well, i dont have experience with those surround things, but i think, you can add them to WAV files
How to make WAV files from your avi?
1)Start VDUB
2)Select Movie
3)Video menu
irect Stream COPY
4)Audio menu: Full processing mode
Compression: select the NONE(or, NO COMPRESSION)
Conversion: Make sure it's 44.1Khz(=44100Hz)
5) File-> SAVE WAV
Then you have your WAV file, apply the surround filters on those WAV's and then you convert the AVI to mpeg
BUT, in stead of selecting the AVI file as your AUDIO source (i suggest u use TMPG). Select in the AUDIO SOURCE column, the WAV file you created and edited.... convert, and there you are, you're doneWanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com
converting mpeg into multi channel audio
By markdueck in forum Newbie / General discussionsReplies: 0Last Post: 5th Jun 2011, 17:35 -
Multi-Channel sound on 4350 not working 100%, (ONLY 2-channel)
By THX-UltraII in forum AudioReplies: 1Last Post: 20th Feb 2009, 05:35 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23 -
Properly encoding multi-channel AC-3 to multi-channel AAC
By PuzZLeR in forum AudioReplies: 1Last Post: 15th Nov 2007, 14:07 -
Convert MPEG-TS 5 channel AC3 to h264 x264 sound problem
By TequilaErik in forum ffmpegX general discussionReplies: 0Last Post: 16th Jul 2007, 19:41
