problems with TMPGEnc. when i select a avi file i get an error message up saying " cannot open or unsupported. avi plays fine on pc though
You need to "unpack" the audio of the AVI file first... How to do that?
1)Dll VirtualDub (www.virtualdub.org)
2)Start it
3)Open your AVI
4)in VIDEO menu, select, DIRECT STREAM COPY
5) In audio menu: COMPRESSION -> NO COMPRESSION (i think that will be the first option)
CONVERSION -> Make sure the little round of 44100Hz is marked, probably 48000Hz will be marked... not good, you need to make it 44.1Khz)
CLICK ON FULL PROCESSING MODE
6)FILE -> SAVE AVI
you're done...
now try to open it in TMPGWanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com
AVI to DVD MPEG (CCE or TMPGenc encoders)
By DJRumpy in forum User guidesReplies: 674Last Post: 15th Oct 2010, 08:46 -
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 15:11 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
TMPGEnc Plus converts AVI to MV2 instead of MPEG movie
By buzzsaw in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2009, 19:36
