I was hoping someone could tell me the formula for calculating an avg bitrate for time for an SVCD and VCD. I know there are calculators that will do this but I want to know the formula.
with the formula, you first need to work out how big the storage media is in KB
I work it out as
74min CD-R = 762570KB
80min CD-R = 803790KB
99min CD-R = 999585KB
then multiply by the ammout of media you are going to use (how many CD-R)
totalkb = mediakb * media_ammount
Then work out the bitrate by
bitrate = (totalkb / movie_length_in_seconds) * 8
this bitrate is for the audio and video so what you need to do is take out the audio bitrate that you want to use.
IF audiobitrate = 224 then
videobitrate = bitrate - 224
Hope this answers your question.
RobDVD to VCD made eazy
http://www.eazyvcd.tk -
File Size(megabytes)*8000(kilobits/megabyte)=[Audio Bitrate(kilobits per second) + Video Bitrate(kilobits per second)] x File Length(seconds)
If you're burning VCD or SVCD you can set file size to around 800-805MB to fit a 700MB(80min) disc. Use algebra to extract the variable you are after. -
Ok yah that works great. Dick_p_t how exactly did you calculate the 800 MBs into the 803790 KBs? Arent you supposed to do 800x1024 which would equal 819200 KBs
i worked it out like this;
80 min cd holds 78 mins of mpeg data comftobaly
78 * 60 = 4680
video
4680 sec * (1150/8) = 672750
audio
4680 sec = (224/8) = 131040
672750 + 131040 = 803790DVD to VCD made eazy
Help with an IF/THEN formula in EXCEL
By Rudyard in forum ComputerReplies: 4Last Post: 13th Sep 2011, 01:53 -
Mpg : Mpeg video size and bitrate calculation
By Bonie81 in forum ProgrammingReplies: 2Last Post: 21st Jun 2011, 22:38 -
Need some info on bitrate calculation
By heman28 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 18:18 -
video bitrate calculation
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Feb 2008, 21:30 -
Newbie needs bitrate calculation advice to convert my 1st PAL to NTSC
By queen_anne in forum Video ConversionReplies: 35Last Post: 20th May 2007, 21:48
