I have an .avi file (with subtitles, not a separate subtitle file) that I encoded with TMPGE. On the monitor it looks fine, but when I burn to VCD the subtitles with 2 lines get cut off on the TV screen. Is there a way to fix this?
Cheers!
Yes,
When encoding ( sorry you will have to re-encode ) under advanced select image placement center ( custom size ) and then enter slightly smaller than VCD( or whatever ) values into the value boxes.
So to shrink the video down by 5% use...
336x230
To shrink by 10%...
320x218
Syncing subtitles with MeGui after an AVS cut
By Homeless Ninja in forum SubtitleReplies: 0Last Post: 11th Feb 2010, 23:52 -
Subtitles in Final Cut or other software?
By perik in forum SubtitleReplies: 2Last Post: 10th Dec 2009, 08:02 -
Final cut pro and subtitles
By akiraku in forum MacReplies: 7Last Post: 6th May 2009, 17:31 -
Subtitles cut off on tv. More than just overscan?
By rayden54 in forum Newbie / General discussionsReplies: 9Last Post: 13th Feb 2008, 11:20 -
Subtitles getting cut off
By shockaholic in forum Video ConversionReplies: 2Last Post: 25th Oct 2007, 10:05
