When converting a divx dvdrip to vcd should i leave the source as 1:1Vga as i change the source to 16.9 ntsc 525 lanes.(or 625 lines if pal.)
I do this because when leaving it on 1:1,some divx's have a tiny black line at the top and bottom and othes have bigger lines,where as with the 16.9 525 lines u get an equal line at the the top and bottom and its the same on nearly ever movie.As the orignal dvd that the divx came from has a ratio of 1.85:1 which when playing a dvd with that ratio your meant to get a line at top and bottom.
So is what im doing ok ????
If you are happy with it, it's ok
But here's what i usually do:
in stead of the 1:1 u use, i use the 4:3 625 Line.. I'm very happy with that, always been happy with those setts -
I always use 2 setting 1:1 and 16:9 display not PAL nor NTSC which depend on how I want output to be. If original source is in full screen format I would go with 1:1 (sometime has to be 4:3) but if wide screen format then I will test both 1:1 and 16:9 in order to get letter box format file.
Note this is only for converting. If I rip from DVD I would set it to match DVD source. -
Originally Posted by Haku
On Widescreen TV's you can zoom out those black borders. -
Ok thanks for the help guys,
But 1 thing i forgot to mention,under video stream setting should i leave that as 4.3 or change it to 16.9.As if i rip a dvd i change that to 16.9.
Done a couple of test and if i leave it as 4.3 and change the video source to 16.9 i get a black line at top and bottom like u should,but if i change the video stream to 16.9 and the source to 19.9 it sretchs out to full screen,but if i do 16.9 video stream and a 16.9 525 lines source i get a really tiny black line on the top and bottom.
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 03:55 -
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 08:25 -
Divx to VCD
By d_unbeliever in forum Authoring (VCD/SVCD)Replies: 16Last Post: 30th Apr 2009, 00:19 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 12:28 -
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01
