I emailed Ann, salesperson at Provideo inquiring about the difference between the PV-256C/T and the PV-256C/T PRO. Here was her response:
"Simply to say that they are using the different chipset and,
PV256 Pro is with more function and good quality than PV256
Price also different and for these we have With TV Tuner or Without TV Tuner."
Has anybody tried the PRO version? Ann's response implies they're using different mpeg chips contrary to what was said in a previous thread. I can't find that information in the specs at the site. Anyway, I'm thinking about trying one. Speak now before I throw away my money if you think it's a bad idea. It costs $210.
Results 1 to 9 of 9
PV-256C/T PRO is using the Conexant CX23415 formally GlobespanVirata iTVC15 aka which petty much the same chip that come from iCompression to start with.
Here list that are using that same chip.
Navis Pro - Pentamedia
PIX-MPTV/P1W - Pixela
GV-MPG3TV/PCI - IO Data
MPG160 PCI TV - Yuan
PV-256C PRO - ProVideo
PV-256T PRO - ProVideo
WinTV-PVR 250 - Hauppague
WinTV-PVR 350 - Hauppague (an upcoming product)
Snazzi IV DVD Mill - Snazzi (an upcoming product) -
All the other cards have some kind of cooling such as a fan or heatsink with the exception of the Provideo unless they're just not showing it in the picture.
That not ever the rigth board if zoom in on the picture you they add black a round the chip to hide what under
If romer are still ture it should look like this
Yes that rigth look just like a Navis Pro card the picture there show is the first PV-256 card -
Somebody needs to review PV256 PRO. Maybe I'll be the guinea pig.
Does it have hardware mpeg decoding like the PVR 350? -
Yes hardware mpeg decoding like the PVR 350 on both ProVideo model do just be ware there two type of cards from Provideo.
PV-256C PRO (Without a TV Tuner).
PV-256T PRO (With a TV Tuner). -
Now the question is who makes better drivers and apps, Provideo or Hauppauge. Opinions?
Intensity Pro firmware update problem on windows 7 pro 64Bit
By ulva in forum EditingReplies: 1Last Post: 5th Oct 2011, 08:00 -
VOB2MPG Pro / Win 7 Pro 64-bit Service Pack 1 Problem?
By Rich_A in forum SVCD2DVD & VOB2MPGReplies: 21Last Post: 2nd May 2011, 16:06 -
Corel VideoStudio Pro X3 and ATI TV Tuner Pro 650 Card Compatibility
By waldodiodio in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2010, 13:41 -
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 14:50 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 17:27
