I have just encoded a movie using DVD2SVCD and when i now look at the mpg file its has "lines", i dont know how to describe it. U can se the lines more when the picture movs fast.
I have never seen this before.
Regards Abel
Do a search on telecine or 3:2 pulldown.
You probably need to use FORCE FILM in DVD2AVI to correct for this problem -
Thank for your ansver!
But it seems like thats if u encode NTSC movies, the movie i have encoded is in PAL....
Regards Abel -
PAL is 2:2 pulldown or field delay.
VirtualDub and avisynth ( integrated into DVD2SVCD ) to do 2:2 pulldown conversion. I'm notpositive how though.
Good luck. -
Thanks for the ansvers!
I've got it to work now, using separatefields/selecteveryPAL in dvd2svcd.
Regards Abel
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 01:06 -
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 00:54 -
Lines across DVD picture...
By xichael in forum Newbie / General discussionsReplies: 2Last Post: 2nd Sep 2008, 07:36 -
why do mpegs play with green flashing lines obscuing the picture??
By cyberraga in forum Software PlayingReplies: 1Last Post: 13th Dec 2007, 14:57 -
Lines in picture, HDTV PCI Card
By dnbrvr in forum DVB / IPTVReplies: 1Last Post: 2nd Dec 2007, 09:58
