I am using Roxio Easy CD Creator Platinum to author and burn a VCD. I have done this before without problems. The problem I am having is the CIF file I am creating is almost twice the size of the input files. I have four MPG files I am trying to burn. They total ~553MB. When I create a simple sequence and create the CIF file, it turns out to be ~839MB. This has happened on two occasions. The first time, I changed the order of the files and it worked fine. This does not work if the files should be in sequence.
Any ideas/suggestions?
update: I reran the file in question through TMPGenc and it appears that everything is working fine now. I assume there was an error in the file that was fixed when I re-encoded it.
Small advice, if I may: Stop using Easy CD Creator! Try something else like Nero, VCDEasy and etc...
WMV to DVD and problem installing Easy Media Creator 10
By jhayes in forum Video ConversionReplies: 3Last Post: 10th Mar 2008, 14:26 -
Easy DVD Creator by Ether Software
By DW49 in forum Authoring (DVD)Replies: 4Last Post: 30th Dec 2007, 14:33 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 15:27 -
Roxio Easy Media Creator 10 verses Pinnacle Studio 11
By snuggels in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2007, 12:10 -
Roxio Launches Easy Media Creator 10
By roxann in forum Latest Video NewsReplies: 0Last Post: 5th Sep 2007, 15:27
