  1. hi, i have a disney avi movie in english, and i have the same movie in mpg in dutch, the video quallity of the mpg is not to good, so i wanne take the audio of the bad quallity and convert it on the good qualltiy movie, is it posible ? i hpe anybody knows .
    ps, i allreaddy try it out with tempg but the audiosound was slower than the video
  2. Member DJRumpy's Avatar
    Dallas, Texas
    Your two different MPEG's are probably useing a different frame rate. Make sure they are both the same. Then you have to ensure that your video clip length is exactly the same, and starts at the same point. If all of these things are right, then your audio should mesh (multiplex) properly.
    You can try fudging with the offset settings using an audio editor. From the sound of it, you said that the audio was 'slow'. I'm guessing you mean it was behind the video somewhat, or did it actually sound slowed down?
    Impossible to see the future is. The Dark Side clouds everything...
  3. thanks for responding, the video sound wast not slowmotion, but it was like you thougt it was, onley they are not two mpg movies . onley one is avi and the bad quallity is mpg, i dont know how to get the sound right , the good quallity is in english and the bad in dutch, so i wanne have both of them, but with good video quallity.
  4. disney, please do not cross or double post questions in these forums.
    thanks.
