my chinsese friend gave me this vcd
but its got chinese dubbing , i mean from 1 speaker there is english from another speaker it chinese .
how can i permanatley remove the chinses dubbing
iam ready to do any thing
1. Convert the "DAT" file on the VCD back to a standard MPEG file (you can do so with VCDGear or CDXA2MPEG -- CDXA2MPEG is a tool in VCDImager and you can use VCDImager Tools GUI if you don't like command console tools: http://www.vcdimager.org/guides )
2. Use TMPGEnc (Files --> MPEG Tools --> Simple demultiplex ) demultiplexor to demultiplex your MPEG into the elemental video and audio components.
3. Convert your MP2 audio back into a WAV file (you can use Winamp with the disk writer output option for this)
4. Use an audio editing program to load the WAV file (e.g., CoolEdit 2000) and copy the english channel over the other one (or vice versa depending on what language you want). Save the WAV file.
5. Use TMPGEnc to re-encode the WAV file back to MPEG-1 Layer2 audio, stereo, at a bitrate of 224 kbit/s. You may want to use a plug-in rather than TMPGEnc's native audio encoder (e.g., tooLame).
6. Use TMPGEnc's multiplex tool to combine the original video back with the new audio (make sure you set it to MPEG-1 Video-CD).
7. Use your favourite VCD authoring program (e.g., VCDImager +/- a GUI like VCDEasy or Nero) to reauthor the VCD with the new MPEG.
Regards.Michael Tam
w: Morsels of Evidence
Chinese subtitles require Chinese font on the computer?
By Haopengyou in forum SubtitleReplies: 0Last Post: 24th Mar 2012, 11:04 -
IdxSubOrc chinese software
By kenryuakuma in forum SubtitleReplies: 0Last Post: 6th Jul 2011, 23:04 -
in Chinese, crisis = opportunity?
By lordsmurf in forum Off topicReplies: 8Last Post: 27th Oct 2009, 15:35 -
subtitles showing like chinese
By forare in forum SubtitleReplies: 1Last Post: 20th Aug 2009, 08:20 -
chinese dvd-r
By superray in forum MediaReplies: 17Last Post: 13th Nov 2007, 16:29
