When i try to use dvd2avi in the process of ripping a dvd, no matter how much tweaking with the settings and different versions of the program i use i get this message: "DVD2AVI caused an invalid page fault in
module DVD2AVI.EXE at 0167:0041a08d.
Registers:
EAX=0042df30 CS=0167 EIP=0041a08d EFLGS=00010202
EBX=00000005 SS=016f ESP=017efef0 EBP=00004420
ECX=cc483996 DS=016f ESI=0071b980 FS=36cf
EDX=0071bfc8 ES=016f EDI=00000000 GS=0000
Bytes at CS:EIP:
dd 59 f8 dd 42 10 dc 08 83 c1 08 81 fa 98 bc 71
Stack dump:
0071b970 00717d78 0071c0b0 00000000 00000080 00000007 0041a460 00717d78 0071c198 00715560 000007e0 0071ad78 00000000 00418669 00713330 007133b0"
This is a mouthful, but i'm going nuts trying to figure out the cause, does anybody have any input whatsoever? I'm desperate on my second day of frustration
Time to re-install windows i think.
DVD to VCD made eazy
http://www.eazyvcd.tk -
That's the horribly unfunny thing, i just finished re-installing it after a full day of tweaking, and even with the new install, there is no change, same effect. Any ideas?
Can anybody help me with this, i've even been so desperate as to search the microsoft database with no results. Can anybody at least point to a possible cause. Smart ripper works 100%, but other tools give me varying error message. Eazy vcd just keeps scanning the disk but doesn't run the program, flaskmpeg gives me a syntax error, and dvd2avi still gives me the above message, i'm desperate!!!!
f-disk your drive, re-format and reinstall everything and it prob will work .
Avisynth - correct defects caused by sharp
By byme in forum EditingReplies: 5Last Post: 3rd Feb 2011, 13:59 -
MeGUI - DAR error caused by latest update?
By Tiernan in forum Video ConversionReplies: 0Last Post: 17th Jan 2010, 20:24 -
cropping interlaced YV12 video caused chroma error
By dphirschler in forum EditingReplies: 2Last Post: 3rd Dec 2009, 11:07 -
Why upgrade RAM caused BSOD ?
By pchan in forum ComputerReplies: 3Last Post: 12th Aug 2008, 07:33 -
WINDOWBOXING... Caused by DVD Player / Plasma...???
By Lathe in forum Newbie / General discussionsReplies: 4Last Post: 22nd Nov 2007, 19:43
