When I cut a NTSC VCD mpeg 1 file I get an audio chirp at the end of the new file. Is the only solution to demux, edit the audio and remux?
Maybe this will help:
when you select the end of a file, please make sure that it can be multiplied by 4. For example, you have selected 10 seconds of a clip. Do not make it exactly 10,00 seconds, but something like: 09,96. This worked for me on PAL.
The Dutchman -
Sorry, Lamont, your way is the only way I've found too.
I try to cut where it is quiet.
Need to render audio in Final Cut Express?
By Bill_Friedman in forum ffmpegX general discussionReplies: 1Last Post: 17th Feb 2011, 23:50 -
MPEG 2 to Final Cut Pro - No Audio
By Huntr777 in forum MacReplies: 5Last Post: 5th Jul 2009, 19:14 -
Metallic "chirp" when appending flv segments with flvbind
By brassplyer in forum Video ConversionReplies: 4Last Post: 6th May 2008, 18:14 -
Need to cut audio from DVD
By UPSdriver in forum Newbie / General discussionsReplies: 1Last Post: 11th Nov 2007, 07:58 -
Mpeg with dual audio. How to cut off one?
By anfield7 in forum Newbie / General discussionsReplies: 1Last Post: 4th Jun 2007, 23:40
