I've read the FAQ but can't make out exactly what it's saying. Can someone explain this to me please. Thx!!!
Results 1 to 11 of 11
Did you read this guide? http://www.vcdhelp.com/autorun.htm What is the special problem?
The problem is I'm not sure what this means..
"And last do you save the file as AUTORUN.INF , remember to select Save as file type: All files in Notepad. Now it is just to drag that autorun.inf to root folder when creating the VCD example like this in Nero creating a VCD:"
I know it means to save the text:
([autorun]
open=start mplayer2.exe /play /close \MPEGAV\avseq01.dat)
Do you include the word *autorun* and where do you save it at?
Yes, type that two lines and save it to anywhere (c:\my documents\) as
AUTORUN.INF !!not AUTORUN.INF.txt!!
That means, save as file type: All files !!not text file!!
Then open Nero and add AUTORUN.INF to the directory structure of the VCD (like explained in the example) -
Another option is get a copy of I-VCD Player. It's a small program (couple of KBytes) that you can add to the VCD. This player is freeware. You have to add three files to the root of the VCD: ivcdp.exe (the player) gui.dll (library) and autorun.inf.
If you leave an email address I'll send you these files. What I like about this method is that it'll always work because it's not dependent on what's installed on the Windows PC and how. You'll supply the PC with the necessary software. I noticed that it also works with "chaptered" VCD's (Media Player maybe too, haven't tried that yet).
_________________
Regards,
Willem
<font size=-1>[ This Message was edited by: willem on 2001-08-16 22:56:02 ]</font> -
Note that the tech tip file ... at least currently leaves out the important "Start" command at front of line... that drove me crazy for a while....................
Also, mplayer2 does support the /fullscreen switch if desired:
for example:
open=start mplayer2.exe /play /fullscreen \MPEGAV\avseq01.dat
Jim -
guns1inger:
Well... I'm working on a low budget charity project and we are trying to create a "marketing" CD and I wanted to do a "slideshow" from a bunch of digital images that would run on a computer and a DVD player ... geezzzzzzzzz you'd think that wouldn't be too hard eh?
Alas... it is, like many things, harder than it looks.....
Thanks,
Jim -
If you have access to a Mac, you can use this handy tool:
http://www.angelfire.com/mac/rnc/files/MMS.html
And if you pop up a level or two, you'll see all of his other useful tools, too. -
Thanks ... alas no Macs here ... but I may need one soon
In case anyone else has the issue I have downloaded the "Media Player Classic" files from SourceForge
http://sourceforge.net/project/showfiles.php?group_id=82303&package_id=84358
I "upgraded" from VCD to DVD format using Nerovision Express
and put that and the vts_01_1.vob file in the top level of the CD.
then did:
open=start mplayerc /fullscreen vts_01_1.vob
I realize this is "bad form" as I've created a video CD that's not really a video CD format but... um it works.... and I'm kinda in a hurry
it works well for the Windows world... going to Mac would be another step.... I think this would work for VCD as well.
also the Mplayerc only works on XP and W2k but there is a version for 9X.
I have not tested yet, but think the following batch file would test for the version of the OS and then play correctly... I did it so no promises but ... hey if it helps somebody let's rock!
@echo off
echo.
echo.
echo The slide show is now loading... this will take a few seconds
echo.
echo.
Ver | Find "XP" > Nul
If not ErrorLevel 1 goto XP_2K
Ver | Find "2000" > Nul
mplay9x.exe /fullscreen vts_01_1.vob
goto end
:XP_2K
:end
Jim
Making a dvd with an english track from a mkv file that has both japanese and english
By andyjc in forum MacReplies: 0Last Post: 12th Feb 2010, 10:41 -
How to make flashes play normally in VCD?
By blair in forum Video ConversionReplies: 5Last Post: 20th Oct 2009, 06:14 -
software recomendations to make an autorun CD
By julitomg in forum ComputerReplies: 2Last Post: 23rd Jun 2008, 16:46 -
Autorun Precedence - DVD & Autorun on the same disc
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2007, 21:26 -
Trying to make AVCD/VCD with audio data
By Vejita-sama in forum Authoring (VCD/SVCD)Replies: 2Last Post: 4th Aug 2007, 16:15
