Hello Guys
I want to buy a video capture card for about 200 dollars which can take both analog and digital inputs and be able to make VCDs and DVDs, preferably with a real time encoding in VCD format.
And since I'd be travelling quite a bit, I'd like it to work with PAL based sources, i.e., cams and TVs in some other countries. Can I buy such a card here? Or can I buy a card here that works only with PAL sources?
Since, the video signals we use here are NTSC, I don't know if some of the popular cards like from Dazzle/Pinnacle/ADS that I buy here would work in other countries! How'd I know?
Thanks for the input.
Enrigue
Results 1 to 1 of 1
How to capture NTSC video from PAL VCR player
By Cyberrock in forum Capturing and VCRReplies: 0Last Post: 28th Sep 2010, 03:36 -
Region Free/ Ntsc PAL Compatible
By veryconfused in forum DVD & Blu-ray PlayersReplies: 5Last Post: 19th Nov 2009, 18:53 -
select a video capture card that compatible with FMLE & linux
By iut_662 in forum Capturing and VCRReplies: 0Last Post: 10th Sep 2009, 03:05 -
NTSC Camcorder feed thru capture from PAL
By INFRATOM in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 29th May 2009, 01:17 -
Pal-60 Compatible External Capture Device?
By Justin-NZ in forum Capturing and VCRReplies: 6Last Post: 22nd May 2008, 10:30
