I currently have four divx movies that play upside down and inverted on WMP 8 and Global Divx player, but not Sasami player or Divx Pro Player 2.0. I rendered all four movies in Graphedit, and found that Windows was using both the Divx decompressor and an .avi decompressor at the same time for each movie. Does anyone know enough about Graphedit to explain why this is happening? Does anyone know why those divx movies play fine in some players but upside down and inverted in others? Do I have to reinstall any codecs? Anyone have any ideas?
P.S. I'm using a nVidia GeForce card, can't remember model no.
Turns out all I needed to do was install the DIVX G400 filter that comes bundled in the Nimo Codec Pack. Problem solved! I still wish I knew why the problem developed though, because it has just happened recently. Previously, I had played those four movies, and they were just fine, until one day, they started to appear upside down and inverted. But if there is one think I have learned while using computers it is to leave well enough alone. Everything works now, so I better not screw with anything!
Colors Reversed? Inverted?
By Abbadon21 in forum RestorationReplies: 3Last Post: 17th Dec 2011, 08:00 -
Inverted Video
By PaPaDeath in forum Video ConversionReplies: 4Last Post: 20th Nov 2008, 21:48 -
Divx Pro free - limited time
By Squash in forum Latest Video NewsReplies: 9Last Post: 26th Dec 2007, 06:23 -
DivX playback problems on Philips DVP 3040 (since installing WinXP SP2)
By mikester2 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 22nd Nov 2007, 12:54 -
embedded videoclip is inverted in powerpoint
By ekbh in forum Newbie / General discussionsReplies: 0Last Post: 16th Jul 2007, 03:48
