SUMMARY
I create a DVD. Everthing I film(family shots) with my camera is very pixelated. Things I copy with the camera of from TV(Sinfield, OLN) is just fine.
STEPS
I copied a TV show with my DV camera and it looks great.
I filmed some outside shots with the same camera and it too also looks great.
Using Canopus board, I brought the two into Premier 6.0. I then spliced the two together and created one film which looks great.
I exported the timeline to movie to a file using the Canopus MPEG SoftEncoder with the following parameters:
[MPEG]
Stream : MPEG2 Elementary Stream
Output : Video && Audio
[Video Settings]
Bit rate : CBR, 4000000 bps
GOP Settings : IBBP, Picture = 15, Closed GOP
Profile && Level : MP@ML, Size : FULL ( 720 x 480 )
[Audio Settings]
Audio format : Wave, Sampling rate : 48000 Hz
[Option]
Encoding Mode : Quality the Most
Sequence Header : Place all GOP's
Everythig seems to work fine. Now when I bring it into DVDit! SE, I'm able to make a DVD just fine.
PROBLEM:
The problem is that when you watch the DVD on the TV, everythig that I filmed myself is very pixelated and jerky. Everything I took from the TV is just fine. Am I using the wrong software? Is there a better encoder that would do the job?
Results 1 to 1 of 1
how do I convert a video that shows square pixels to no pixels?
By sxpredman in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2010, 02:56 -
Another question: Converting square pixels into round pixels.
By Earthling2000 in forum Newbie / General discussionsReplies: 13Last Post: 23rd Nov 2009, 10:20 -
Editing a DVD video in Premier
By smallears in forum MacReplies: 8Last Post: 9th Aug 2009, 12:55 -
Blotchy Pixels On My DVD
By Nitro89 in forum DVD & Blu-ray PlayersReplies: 19Last Post: 14th Apr 2009, 08:45 -
Adobe Premier Pro to dvd
By tat2loo in forum Newbie / General discussionsReplies: 7Last Post: 29th Apr 2008, 12:57
