  1. I keep getting the message that avi is not supported in TMGE yet I
    know I have done dozens of movies in it. It says unrecognized file.
    I know the file is good but to be sure I tried to redo one that I had
    done previously which turned out fine and got the same error message this time when I tried to do it as well as trying others I had done before.
    I installed the new SP1 on my XP windows and it took it down. I was
    able to repair windows and everything works now but TMGE I can't
    remember when it stopped working if it was after this or not.
    I am getting an error message in another rendering program about the avi format. I am wondering if I am missing a code or windows upgrade messed up the codes. I don't know which one to look for.
    Any help would be appreciated. I have a feeling that I am missing a
    code. I looked for DirectX and did the checking thing and it says it
    is working It does not show iin the add/remove programs but all the
    dll's are there and the file folder.
    thanks for any advice, I am lost without this program.
    Meggie
  2. I think you are missing a codec too.....try M$ mpeg4
    http://www.divx-digest.com/software/mpeg4codec.html
