Results 1 to 10 of 10
  1. ok, i need helpin makin a vcd(im a NEWBIEE)
    i wanna talk on aim, so here my sn
    lonely dom714
    i would really apreiate anyones help
    thanxx
  2. Have you tried reading the guides.
    Craig
  3. i got to some part but i don't kno where to start to say wat my prob is
    so i need ppl to talk on aim, i think it's so much faster
    May 2002
    louisville,ky
    you need a capture card,big harddrive,7200rpm at least 500mhz system or faster,mjpeg codec or huffyuv,tmpgenc and virtualdub,cd burner that supports overburn,nero to burn vcd.cap with your card in mjpeg load into virtual dub sync audio,load into tmpegenc encode load into nero and burn.you can download templates for tmpeg to fit longer movies on a 700mb cd,or you can play with the vbr settings yourself.the only problem i have encountered are audio sync problems and i figured that out quick.always use uncompressed audio.even if virtual dub changes frame rate in your avi...say 29.970 to 29.966 tmpeg will compensate and you should not have sync problems.ok...let me know how it goes
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    DRfrankenpimp - i think you scared him good ..
    May 2002
    louisville,ky
    this stuff is really easy once you get the hang of it
  7. thanx for all that but i need some aim help, on aim
    anyone???
  8. Член BJ_M's Avatar
    Jul 2002
    Canada
    what the heck is aim anyway .. i hope its not some AOL creep thing .. i thought aol was blocked from using pHp .. or was that set top tv web
    Hamilton, Ontario, Canada
    It's an instant messager and a great way to catch a couple of dumb assed virii. Forget it, I don't talk on that insecure crap.
    Jeremy Morrow
  10. where do u want 2 chat
