I had my family videos put on DVD, and asked for MPEG2 format. Mistake?
The DVD they gave me has a mp2 file and a mpa file. My computer will not let me copy the mp2 file to the hard drive.
I want to open the files for editing in Pinnacle Studio 8.
Have I made a horrible, basic error?
Thanks!
karenhvb
sounds like they gave you a data dvd .. because thats not a normal dvd ..
but you can edit them fine ---- im not sure about Pinnacle Studio 8 if it can take mpeg file (which those are) ...
if it cant - you will need to convert the files to avi .. which is easy ..
you will need to install a mpeg2 codec . installing powerdvd or windvd will take care of that . get and install huffyuv codec also
then load the files into either Pinnacle Studio 8 or if they still will not load - load them into tmpgenc mpv is video and mpa is audio..
then in tmpgenc -> file -> save as -> avi -> type huffyuv (set compression to best on right window in config of huffyuv) -> save
load the resulting avi into Pinnacle Studio 8
the avi may be over 4 gig (may be problems for you) or as another option ... personally i would just convert the audio to pcm with tmpgenc and frame serve the video ..
if you need to do this -- thats a next step and is very easy to do ... -
as to why you cant move them to your hard drive -- what size are the file ?
it's not the size of the file. The message I get in Windows Explorer is that 'the parameter is incorrect" on the mp2 file
karenhvb -
Hi,
i am not sure, but i think win98 is in trouble with such a big-file size. try to use tmpgenc and split your big file into smaller pieces. i think this will solve your problem. if do not how, let me know.
greetz
Jam_bo
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 19:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
help recovering DVD folders n vob files from deleted hard drive
By grafixx in forum ComputerReplies: 1Last Post: 16th Jan 2010, 15:44 -
DVD recorder that will read movie files from ex hard drive?
By siratfus in forum DVD & Blu-ray RecordersReplies: 9Last Post: 3rd Oct 2008, 15:26
