What setting should I use to encode a 600 meg divx.avi movie to mpeg1 so I can get the movie on 2 discs through TMPGEnc. without losing too much quality???? Thanks very much.
Bill
A recommendation. Encode to SVCD (MPEG-2)
resolution 480x480/576, rate control mode: VBR 2pass
The average bitrate depends on the time of the movie. Use FitCD to calculate the bitrate to fit your movie on 2 CDs. Min rate 500, max 2500. The max bitrate depends on your DVD player's properties.
If you use TMPGEnc set the motion search precision to High Quality.
Also you may play around with the filters .
TV Wonder 600 and TV Wonder HD 600, is there any real difference?
By jedi55 in forum Capturing and VCRReplies: 3Last Post: 20th Mar 2011, 22:53 -
MPEG-4 (DivX & XviD) movie discs no longer recognised by players.
By Sproggins in forum Newbie / General discussionsReplies: 11Last Post: 6th Sep 2009, 16:09 -
How do I reduce the file size of my 16 meg movie?
By Luckyword in forum MacReplies: 7Last Post: 20th May 2009, 18:53 -
DivX Player 6.82 cannot play AVI movie
By chuckycheese in forum Software PlayingReplies: 10Last Post: 24th Jul 2008, 23:10 -
X264 - Divx HD or something that will play on my Kiss DP-600
By potatoprince in forum MacReplies: 4Last Post: 9th Feb 2008, 16:27
