    Aug 2002
    hi
    i'm using spruceup (full) to create a background with a play button to start playing only one video with no chapters(video is 1hour 39 mins long).what i want to know is how do i associate the play button with the video i want to play?
    also i tried to use the video to use as first play so the video would play stright away spruceup formatted it to dvd compiance but when i imported it in to the lastest nero version and set it to burn a dvd having dragged the required vob files etc into the vts video folder that nero started the burn process when it gave me the following errors
    1)violation against dvd specification detected
    2)dvd-video files reallocation failed
    what is nero telling me
    i would be very gratefull for any help as i have only just bought thepioneer 104 burner and haven't been able to burn a dvd!!!!
  2. Member tumbar's Avatar
    If you have created a button and imported you video asset into spruce, the easiest way to associate the button with play of that video is to drag the video from asset window to the button you have created on the screen.
    When you use Nero, choose create a udf/iso dvd. Spruce should have created a VIDEO_TS and AUDIO_TS in your spruceupworking folder.
    Drag both folders to the compilation window and burn.
    regards
    Jim
    Aug 2002
    thanks
    i try what you.ve said and report back
    thanks much appreciated
    Aug 2002
    :P jim
    tried the two things you advised both worked a treat button plays video and nero burned the dvd and it plays with no problems on my stand alone pioneer dv525 a treat.
    many thanks again
    i owe you one cheers
