I have a movie I ripped using Smartripper, where I told it to split the vobs by chapter, which made it easy to play off the HD. Now I want to burn them to DVD-R, using the different vobs as chapter points.
I first tried using MyDVD 3.1. It plays fine, but after each file you have to go back to the menu, you can’t play them in order. The nice thing about MyDVD is that it accepted the vobs directly once I renamed them to .mpg, with no re-encoding or demuxig.
I heard that DVDit could play all the files in order, so I tried it. Only problem is that when I preview the DVD I hear the sound. But once you build the DVD, DVDit demuxes and it looses the sound. I know I could use a program to demux ahead of time, but wouldn’t that just be asking for audio sync problems? I love the way MyDVD takes the vobs/mpg directly. I just wish there was a happy medium. Any suggestions?
Results 1 to 1 of 1
AnonymousGuest
subtitles with DVDit 6 PRO
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2010, 13:51 -
Replacement for DVDit Pro HD 6.3 Final
By GrampaD in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Oct 2009, 11:04 -
Subtitle Sync Problems in DVDit Pro
By aquaorbis in forum SubtitleReplies: 0Last Post: 5th May 2009, 22:40 -
Has anyone used Sonic Scenarist or DVDit pro HD?
By jbandy1 in forum Authoring (Blu-ray)Replies: 16Last Post: 18th Feb 2009, 01:08 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 10:52
