So I made a copy of my Shallow Hal DVD by connecting my DVD player to my wintv card and capturing the same way I do TV shows. Turned out OK I guess. But this Ripping method will do the same thing for me? Which way is better, the way I did it or this ripping method?
The ripping method is better, You get an exact digital copy. Even if you are going to convert it to vcd is always wise to start with the best souce possible. You will always have quality loss when running it through a capture card.
yeah, my friend rips DVD using this method.
DVD player connect to VHS player, then record on to tape. lol
File size differs from data size--HUH?!
By atoledo123 in forum MacReplies: 2Last Post: 9th Sep 2011, 14:19 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 05:50 -
Huh? Weird board message never seen before
By DRP in forum FeedbackReplies: 2Last Post: 7th Apr 2008, 06:46 -
What? Macrovision hitch on firewire transfer from mini-DV to DVD? Huh?
By knowhow in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 20th Feb 2008, 00:47 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 10:22
