I code DV format to MPEG-2 with TMPGEnc. Then I author it (add chapters and menus) with Ulead DVD Workshop. When I want to burn it, step 4 (multiplexing video/audio) takes a long time (aprox. 1.5 hours for 1.5 hour of video). Is it normal and do you have this step 4 which lasts long time?
Thanks...
That's a long time. I'd say multiplexing should take 5 or 10 min, IF you brought in a compliant mpg.
What are the specs of your audio stream? Did you check the "do not encode compliant files" box if using v 1.2? Give more specific info. -
I brought compliant MPEG and I checked the option "do not encode compliant files". Estimated time is 1.5 hours but it seems that multiplexing is going much faster. I think about 15-20 minutes. Do you think that this is long?
total file size?? Processor speed video card?? time is relevent as Einstien said, whereas 20 min on 1g file would not be long it would for 10M file unless that 10M file was run on a pci video card and or PII or Duron <1Ghz...
The Force is a strange and powerful thing -
Perfect, if muxing to the same HD. Should be less if on RAID or to another HD. As about Ulead estimations ... final one "finalizing VOB" or something, seems to be only one right.
Originally Posted by JediXR
Question about Subtitle Workshop
By tcory in forum SubtitleReplies: 1Last Post: 15th Jul 2011, 23:10 -
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 02:04 -
Subtitle Workshop 2.51 question CLI vs Gui.
By Maikeru-sama in forum SubtitleReplies: 0Last Post: 4th Jul 2008, 21:27 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 02:55 -
DVD Workshop 2 on Vista
By jaffacaique in forum Authoring (DVD)Replies: 6Last Post: 22nd Aug 2007, 09:16
