    Hamilton, Ontario, Canada
    Okay, I get clicks of sound in between joined MPG segments in TMPGEnc and it's gross, so over the weekend I took a certain liking to frameserving edited AVI segments in VirtualDub through to TMPGEnc where they get converted quite nicely into a beautiful, seamless VCD standard MPG. I'm very impressed with frameserving. HOWEVER, I used to batch encode tons of AVI segments overnight in TMPGEnc using it's batch feature. I'm assuming I can't do this now because frameserving appears to only serve one SET of AVI captures. Is it possible to have VirtualDub frameserve several AVI captures that have been divided into segments? Could I open up several copies of VD and start several frameservers running a series of VDR files? That way I could have TPMGEnc convert a whole slew of captures overnight while I'm asleep, which is pretty helpful.
    Mar 2002
    chicago
    you're probably better off using avisynth.
    I know there's commands for using segmented avi sources, and you can just create a script for each set, and add each of them to TMPG's batch and encode overnight.
    what are you askin' me for...
    I'm an idiot!
    Aye carumba, nothing but scripts and a total absence of GUI as far as the eye can see. Great app, but not very user friendly. Is there a guide out there that covers AVISynth scripting in reference to batch frameserving AVI segments?
    Jun 2001
    Surface-of-the-Sun (AZ)
    I open up several copies of virtualdub on occasion and there hasn't been a problem. I use it to test encode something on a file I'm editing in another instance, or to batch encode overnight. Just don't frameserve from the same file twice simultaneously, I guess. I haven't tried avisynth but it sounds like the deciding factor would be if you are batch encoding three files occasionally or 150 a night.
    Mar 2002
    chicago
    http://math.berkeley.edu/~benrg/avisynth-reference.html
    avisynth is a very good program--and it will speed up encoding compared to using VDub. it's not that hard to learn--you can even use VDub plugins
    if the above link doesn't help you enough, search the forums here, or at doom9
    I'm an idiot!
    Well the answer to my question is yes. Went home tonight and tried it out and you can batch encode a series of frameserved AVI chains by running several VirtualDub frameserver sessions. I made a screenshot of three frameservers running and TMPGEnc batch encoding them all, but I guess BBCode doesn't allow for JPG links. At least, I couldn't get it to link to my screenshot, but here it is:
    http://www.interzone23.com/fun/batch_frameserving.jpg
    As for AVISynth, I'm very intrigued by this. At least I have my problem solved with this stop gap until I figure out how to sharpen my scripting skills in AVISynth. Thanks for all the help and great suggestions guys.
