Almost everytime i try n burn a vcd with nero it gives me an error: Medium Speed Error. Then i try it at every speed available and it still doesn't work. To make it even worse today i copied a vcd disc to disc and it worked fine but when i tried to make a second copy disc to disc it kept giving me that medium speed error. I know ur supposed to burn VCD's slow but the only speed in Nero that has worked for me is 16x.
Results 1 to 11 of 11
who says you're supposed to burn VCD's slowly? if 16x works, then use 16x.Originally Posted by prnking
seems pretty simple to me
what are you askin' me for...
I'm an idiot! -
it only worked once so do you know how to get around the error or what the error is or why the error happened
you never said that it only worked once.Originally Posted by prnking
I don't know what that error means, but try looking...
http://www.google.com/search?hl=en&ie=UTF-8&oe=UTF-8&q=medium%2Bspeed%2Berrorwhat are you askin' me for...
I'm an idiot! -
hmm, medium speed error... What setts do you use with nero, cuz i know that sometimes, the setts in nero are a pain in the ass(sorry for the expression, but they are
This could well be the cure, as the newer type of disks may not be compatible with your writer. Quite a few 40X CDR wont work with older writers without a firmware upgrade.Originally Posted by eatin sammiches for lunch
Now my stupid azs tech support people can't tell me the brandname for my CD-R. It says JustLink 16x10x32x the
front and in the device manager it's called RW-161032. I've been trying to update the firmware but
I can't find the right shit to DL. So any help in identifing? the CD-R or links to good places to find the firmware would help a lot. Thanks in advance! -
Isn't JustLink a Ricoh thing? At least they have a model named "16x10x32x drive RP16/10A-SK" maybe that could be the one?
Nero CD/DVD Speed (4.7.7.5) -Error
By bluemoss in forum DVD & Blu-ray WritersReplies: 14Last Post: 12th Jan 2012, 00:08 -
Error, after burning a dvd with nero
By Remyisme in forum Newbie / General discussionsReplies: 13Last Post: 27th Sep 2008, 03:11 -
Error Nero AAC - no HC
By albo23 in forum Video ConversionReplies: 1Last Post: 17th Aug 2008, 15:06 -
NERO burn error
By Budokhan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 21:58 -
Help. Nero error log
By R!ffraff in forum Newbie / General discussionsReplies: 7Last Post: 3rd Mar 2008, 16:22
