I'm getting ready to buy a dvd burner and had a question. A salesman at a local audio/video store told me that DVD's cannot be copied because of copywrite protection...which I'm sure is able to be bypassed. But he also said that even it you could get a round it, the Dolby Surround encoding could not be copied. Is this true?
I guess the easy way to ask is.....can I make an exact copy of a DVD that I rent?
Thanks,
remelad
False. Removing macrovision is easy.Originally Posted by remelad
False. The Dolby Surround encoding can be streamed into a AC3 file. You will need authoring software that supports AC3 to use it.Originally Posted by remelad
Yes you can but an "exact copy" can be more trouble than its worth. Most people just keep the core movie and drop the menus and extras.Originally Posted by remelad
Now if you want to learn how to do all these things you will need to catch up with some "lite" reading. Refer to the "how to" section on your left.
6 wav to DVD with surround sound
By kkkkamy in forum Authoring (DVD)Replies: 7Last Post: 8th Feb 2010, 17:30 -
DVD to AVI with surround sound
By Sutekh in forum Newbie / General discussionsReplies: 1Last Post: 12th Aug 2009, 13:46 -
Good Surround Sound for Sony RDR-HX720
By abdul_sma in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Nov 2008, 10:23 -
Make an xvid/avi from DVD but keep original ac3 surround sound?
By coolchris in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 08:35 -
5.1 Surround Sound on DVD
By Adhishyajnik in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2007, 02:57
