I saw some people said set DMA to the hard drive. Can anyone please tell me how can I set it to my hard drive ?
I'm having Western 60GB HDD. Thanks.
Well I havent set the dma to hrd drive yet, but if you want to, in Windows go to,
1. Start
2. Settings
3. Control Panel
4. System
5. device Manger
6. Click on generic IDE hard drives Properties,
7. You will see a DMA option,
8. Check it,
9. restart your comp!
Where is the wine the new wine? Dying on the vine. -
If you turn the DMA on, will it do something bad to the computer? I'm asking this cause I don't want to screw up my computer.
Usually, if you enable DMA for a device and reboot windows, if the device doesn't support DMA mode, windows will have DE-selected DMA and you don't have to worry about it anymore. If the device DOES support DMA mode, then it will remain enabled.
It shouldn't wreck anything.
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 19:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 12:06 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 16:58
