I made a menu consisting of an intro mpeg, still menu, and 5 clips based on the guide at http://www.vcdhelp.com/forum/userguides/104503.php. Everything seems to function correctly except the menu still does not come up on screen. The still is a bitmap I captured using Windvd, edited with Lview, and converted to mpeg using VCDEasy. Any ideas why the still does not display? Thanks
Results 1 to 11 of 11
What are you using to play your VCD?
Does it work on anything else? (e.g., software DVD player on your PC)
Regards.Michael Tam
w: Morsels of Evidence -
yes it works on the pc with windvd. I noticed that the still is 704 x 480 and all the clips are 480 x 480. Could it have something to do with that?
I also had problem with menus created by VCDEasy on my Pioneer DV444.
They were not shown but they worked.
Now I downloaded the beta version RC2 of MJPEG tools and the menus or still pictures are displayed.
Give it a try.
Riccardom -
I tried installing the picvideo mjpeg tools under the tools section here but vcdeasy doesn't read it. I have a dv444 also. Riccardom, please explain further how you solved this problem.
I got the same problem with my pioneer dv 440 player. Where to get mjpeg tools rc1. is this a vcdeasy program???
i see mjpeg tools 1.6 beta 1. Is this the program version your talking about???
yes, 1.6 is the version I have with vcdeasy 1.1.2. Dunno what the heck "beta version RC2 of MJPEG tools " is...
Sorry for being late, but I didn't read the forum
If you go to www.vcdeasy.org there is a "beta versions" page
(you must register before entering)
and there you can find the version I used:
Mjpeg Tools (v1.6.0 rc2, 564 KB)
It builds mpg files bigger than the normal versions, but they work on my DV 444
Hope it helps
Riccardom
multiavchd menu question
By mysts in forum Authoring (Blu-ray)Replies: 0Last Post: 27th Apr 2011, 12:12 -
Menu Question
By coloradoguy in forum Authoring (DVD)Replies: 5Last Post: 22nd Jan 2009, 01:04 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
DVDlab menu question
By rizay in forum Authoring (DVD)Replies: 3Last Post: 12th Dec 2007, 08:54 -
question about dvd menu button
By HDMI in forum Authoring (DVD)Replies: 5Last Post: 23rd Jun 2007, 22:06
