Have noticeable pixels after converting avi file (digital8 PAL source) to mpeg2 by Ulead VS6 and cannot get them out even at higher continous 9000 bit rate. The source materila is clear and crisp. I was wondering whether it is Ulead that is causing those quality probems and perhaps I should try some other tools.
Any idea what could be wrong?
Can you give us any more information? Are you converting to MPEG-1 or MPEG-2?
What motion detection settings are you using?Impossible to see the future is. The Dark Side clouds everything... -
thanx for reply....
I am converting to MPEG-2 by using Ulead PAL DVD template, 25fps, with fixed bit rate 9000, but I am not sure if I understand what motion detection settings are...where can I find this information?
AVI to MPEG2 Conversion Software
By cyberboy in forum Video ConversionReplies: 3Last Post: 7th May 2009, 21:54 -
DV-AVI conversion to mpeg2 or DVD
By obadvw in forum Video ConversionReplies: 6Last Post: 17th Apr 2009, 07:59 -
AVI to Mpeg2 conversion
By carlmart in forum Video ConversionReplies: 122Last Post: 13th Mar 2009, 07:04 -
MPEG2 to AVI conversion.
By fl3tty in forum Video ConversionReplies: 5Last Post: 4th Dec 2007, 01:31 -
AVI to MPEG2 conversion
By Alexstarfire in forum Video ConversionReplies: 8Last Post: 6th Aug 2007, 19:42
