Hi!
I have a divx video and i need to know the audiocodec.
I have viewed fileinformation in vitualdub 1.4 and it says
audio stream:
sampling rate: 48khz
channels: 2 (stereo)
smaple precision: 16bit
compression: unkown (tag 0161)
preload skew: 2 samples
# of frames 14168
min/avg/max/total frame size: 3121/3121/6242 (43186k)
I hope someone can help me!
Download Nimo Codecs Package 5.0...Install in FULL see if it works..
If it doesn;t work try downloading Angel Potion Codec, or
Krystal Studios <-- this one might cause you problems so use this as a last resort...See if it works...
go to the Tools section and look for divx 3 and 4 codec. try installing the divx3 audio codec.
YEAAAA I helped someone..yeaaa yeaaa YEAAA !!!!!
Im soo cool !
YEAAAAAAAAAAAAAAAAAAAAAAAAAA !
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
[Question] How to insert an SRT (Subtitle) file into an AVI file?
By Greg14 in forum SubtitleReplies: 5Last Post: 30th May 2009, 04:54 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
add srt file to avi, xvid 700mb movie file
By volam in forum EditingReplies: 2Last Post: 30th Jan 2008, 21:22 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 11:39
