Yes, I'm having problem when I'm capturing a movie/movieclip with my "hauppauge wintv pci radio" tv-card, there is one irritating frame or what you should call it in the top of the capture, here you can watch a sample: http://www.tavelsjo-bangolf.com/example.avi there is just a 5 sec long clip (578 kb)... Take a look at the top of the movie, I don't want that frame to be there...
One more thing, what's about the quality? I mean, is it good/bad quality and is 30mb too much for 4 minutes and 30 seconds in that quality?
I also had problems with irritating frames during the time of fading effects in Premiere. I deinstalled all mpeg plugins and "unnecessary" codecs and reinstalled the capture software and Premiere. Now the picture is clear again. So, reinstalling drivers might help.
greetings, Hendrik -
To remove that 'frame'. Just crop it out, using the Crop Options...
If you're using VirtualDub, go to Video -> Cropping... -> Set Bounds... And accomdate to your liking. And don't forget to choose Enable after setting the bounds!
Sound gets irritating while scroling mouse in some internet pages
By Artas1984 in forum AudioReplies: 7Last Post: 2nd Oct 2011, 07:49 -
9911u "TBC" - creates tearing at the top of the frame?
By sphinx99 in forum RestorationReplies: 3Last Post: 8th Mar 2010, 21:17 -
POSSIBLE? Captured 8mm Movie Frame by Frame Editing
By PLW in forum Newbie / General discussionsReplies: 15Last Post: 21st Jan 2009, 14:21 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 23:53 -
Irritating problem (flashing vertical bars)
By weko in forum Newbie / General discussionsReplies: 5Last Post: 30th May 2008, 07:40
