I don't know why I can't play .mpg file at WMP. I have uninstalled and reinstalled WMP 7.1, DirectX 8.1. I can play .wmv, .avi, .dat, etc. fine. But when I open a .mpg file (I have several .mpg files which all work since I test them in my laptop), it gave me this sign:
The DLL "cpuinf32.dll can not be loaded. OS reports: One of the library files needed to run this application cannot be found.
I've tried to play the .mpg in DVDx, but the file doesn't play at all.
Please help or advice what I need to do to fix this problem. Thanks for much.
Sounds like a directx problem.. although you say you have reloaded
direct x. Directx is needed to link mpg codec's for direct show.
A quick way to refresh the directshow/mpg codec is to download
DVD player software (depending on your OS).
for win98/98se and ME choose power DVD (v.3 works / v.4 have not tested)
for win2k/winXP choose winDVD (any version)
hope this helps.
Try for awhile then uninstall (do not remove shared files)
Help regarding playing specific video file in WMP
By sohaibrazzaq in forum Software PlayingReplies: 4Last Post: 25th Sep 2011, 12:19 -
Playing one AVI in WMP there's no audio
By mahogany in forum Newbie / General discussionsReplies: 0Last Post: 25th Dec 2010, 14:05 -
Playing flv files with WMP
By INFRATOM in forum Software PlayingReplies: 1Last Post: 22nd Jan 2009, 03:12 -
Playing AVCHD on plasma using WMP=wrong AR
By EliG in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 29th Oct 2007, 11:54 -
Playing wmp music samples at Amazon
By NiteLite in forum Newbie / General discussionsReplies: 19Last Post: 12th Aug 2007, 14:02
