I use Spruce Up that accepts Dolby Digital (ac3). There is a demo of this available on the net and a crack (i have one). Also DVDwise supports ac3 but it seems to have sync problems and it doesnt seem to author properally. The only prog ive seen that supports DTs is Maestro..this is a complicated high end program for proffesionals..I have a copy but Ive never got it to work on XP !
Impression Pro - which is not that expensive , has full support for 5:1 ac3 files
DVD Worshop accepts AC3. With v1.2 you have to mux video and audio before bringing into the app. With upcoming v1.3 you can bring in elementary streams
Originally Posted by wizzy
Audio encoding AAC to AC3 for multiAVCHD authoring
By ejai in forum Authoring (Blu-ray)Replies: 6Last Post: 3rd Dec 2010, 11:00 -
TMPGEnc Authoring Works 4 (AC3 Plugin)
By likwid8 in forum Authoring (DVD)Replies: 1Last Post: 25th Oct 2010, 03:30 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:16 -
Authoring a DVD with AC3 640 bitrate - can it be done?
By Slimbo69 in forum Authoring (DVD)Replies: 11Last Post: 9th May 2008, 09:11 -
Authoring program? (m2v's/ac3's/mpg'sVOB's)
By RobAdam in forum Newbie / General discussionsReplies: 1Last Post: 11th Nov 2007, 06:53
