Hello!
I own a great Star Trek VCD collection. I would like to convert them to xvid for the convenience of 1 cd by movie when I travel. I had no problems with some them. I extracted the movie with vcdgear GUI, then I converted to xvid using VirtualDub.
But some of my movies had problems. VCDGear was not able to extract the mpeg. So I decided to move the DAT to my hard drive, hoping VirtualDub would be able to open them directly but the operating system told me that it wasn't an authorized MS-DOS function... I have to admit I don't know exactly what it means.
Can you help me with this?
Thanks a lot,
Nicolas
Results 1 to 9 of 9
Do you have any problems playing VCDs or viewing the associated dat fill on the PC you are trying to do this on??
Yes and that's what's strange... the movie works perfectly on my computer... I use WinDVD to watch my VCDs and I have no problems watching them...
Nico,
VCDgear is a program that gives many ppl problems! I've seen
it totally wreck mpeg files.
Download a copy of VCDEasy (see tools section link, left hand side)
and install it. Goto the tools, click on the button MPEGTOOLS,
goto the Cdxa2mpeg dialog at the bottom and use that
to process your .DAT files. You will then be able to load the
newly created x.mpg files into Virtual Dub without a problem
Note: processing from the hard drive is an advantage so if you
have the space copy your dat files across to your hard drive. -
Thank you but I already tried that! VCDEasy refuses to copy to my hard drive unfortunately and when I convert with VCDGear it refuses to load in Virtual or TMPGEnc... quite boring
... It really seems to come from the VCD, does some protection systems exist on VCD?!?!?
yeah.. there are ways to prevent file copying (you have to use clonecd ordoes some protection systems exist on VCD?!?!?
blindwrite to copy the whole cd as is)
Sometimes, just on occasion you can feed the .dat as the
source video and audio into tmpgec and it will transcode
a new mpeg correctly from your VCD. Only if you feel lucky. -
So... the best thing to do would be to write a new cd using cloneCD? because yesterday i tried creating a .nrg image with Nero and then extracting the file with VCDEasy, it didn't worked!
Which program would you recommand me so, Blindwrite or CloneCD?
By the way, thanks a lot for your help
No.. even with clonecd it will copy the disc as is - if you can't do a filei tried creating a .nrg image with Nero and then extracting the file with VCDEasy, it didn't worked!
copy from the original you won't be able to do it from the clone cd
copy either.
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 02:51 -
DAT to MPEG 1
By MI6 in forum Video ConversionReplies: 14Last Post: 8th Feb 2009, 15:01 -
How to corp a dat or mpeg file to mpeg
By onlyrasel in forum VCDEasy GeneralReplies: 1Last Post: 26th Sep 2008, 23:18 -
Extracting jpg photos from the ITEM####.dat files in the VCD segment folder
By H-Man1953 in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2007, 06:54 -
dat to mpeg - no sound
By goshz in forum Newbie / General discussionsReplies: 9Last Post: 22nd Jun 2007, 04:24
