  1. I’m using Adobe 6.5 to output to mpeg2 from the time line with the new Main Concepts encoder. When I try to import the files to DVD Workshop is doesn’t except the file with the m2v extension. What settings do I need to change so this doesn’t happen?
    Jim
    Apr 2002
    Jim
    Try to re-install DVD Workshop. I had similar trouble with Ulead's Movie Factory. I just started to "Remove Software" and picked the "Repair" option. Sometimes Ulead's products wig out when other video editing software is loaded after them.
  3. Nope that didn't work. Any one else?
  4. Member Nolonemo's Avatar
    Los Angeles
    try renaming the file to .mpg
