I posted a previous message about audio problems within TMPGEnc and changed the priority of "DirectShow Multimedia File Reader". The audio loaded up with it. However when I went to encode the AVI, I got an error message stating "Tmpgenc has caused an error in MP43DMOD.DLL....... Tmpgenc will now close". Anyone?
After I set it back to default, I'm going to be left with the same problem I had before. I'll be able to load up video, but no audio and I'm not sure what codec I need.
you're GOING to? you havent tried it? it should reset the filter to -2 or something, then use something else in a effort to decode it.
What the first original setting before set to default. If you set too high I'd recommend set to 1 or 2 (you can add 1 by 1 until you can load and encode avi file).
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Error message in TMPGEnc 3 with Divx Authoring...
By blasedeviant in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2008, 13:29 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16
