Hello everyone
Wondering which dvd authoring program is the best, and what do u guys use? any commnents?
thanks
I am using DVD Workshop, I find it easy to use, it supports motion menus, you can have nested menus, it will author without reencoding if you feed it compliant files, it accepts AC3 and the coming 1.3 version will accept elementary streams. Its menu templates are easy to use as starting points for what I want to do.
I'm sure there are cheaper authoring programs out there that are fine also. -
i use a variety of programs, i edit with premiere and i make menus withspruceup or dvd work shop, id recommend the ulead line for software that does a myriad of tasks easily and efficiently
maestro and scenarist are very good - if you need the things they can do .. which in many cases you dont ..
a excellent authoring program is "Impression pro" also ..
DVD authoring program for mac
By BIFFtheSTIFF in forum MacReplies: 2Last Post: 25th Apr 2011, 02:23 -
Which dvd authoring program could I use...
By sagat93 in forum Authoring (DVD)Replies: 5Last Post: 14th Oct 2009, 21:43 -
which dvd-authoring program is better?
By siluet in forum Authoring (DVD)Replies: 9Last Post: 8th Oct 2008, 14:25 -
The Best DVD Authoring program
By Random490 in forum Authoring (DVD)Replies: 6Last Post: 12th Dec 2007, 04:10 -
Program for basic DVD authoring
By netimen in forum Authoring (DVD)Replies: 7Last Post: 11th Jun 2007, 19:25
