  1. I have a Divx avi file of a movie and am trying to put on a vcd. I used Nero 5.5.9.0 and it encoded it and I burned it at 24x. The problem is with the playback I get these color blocks popping on the screen and the picture seems to change scenes a little jumpy? The original playback of the divx was crystal clear ,what happened to the vcd? What am I doing wrong ,or what can I try to get a better quality vcd?
    Mar 2002
    chicago
    the problem is that you used Nero to encode the movie.
    don't do that!!
    do this instead:
    http://www.vcdhelp.com/tmpgenc.htm
    what are you askin' me for...
    I'm an idiot!
    Apr 2002
    The State of Frustration
    What template did you use?
    Hello.
  4. the problem is that you used Nero to encode the movie.
    don't do that!!
    do this instead:
    http://www.vcdhelp.com/tmpgenc.htm[/quote]
    Ok I am using Panasonic MPEG Ecoder now and it says it takes 6 hrs?
    Does Tmpgenc take as long , or which one is better to use for quality and time
    Thanks again
  5. Member DJRumpy's Avatar
    Dallas, Texas
    TMPGenc will usually beat any of the other encoders for quality on VCD MPEG-1. To anser your second question, the better the quality settings, the longer it will take to encode.
    Impossible to see the future is. The Dark Side clouds everything...
  6. if tmpgenc dont work try AVI 2 VCD seems to work for my divx but takes fookin ages lol 6hours sometimes but its the quality you r lookin for plus dam nero takes 2 fookin long anyways lol 56 hours it took me to encode a 44min film so i used tmpgenc and it was dont in a hour :P injoy oh what film you tryin 2 do???
