How do I put a DVD film onto 2 discs as I only have 80 Minute discs and the DVD films are too long?
Please Help
derrows site wont help u because as your titles saysOriginally Posted by DVWannaB
"how do i put a dvd onto 2 vcd discs"
the link givin to u only pertains to dvd to dvd-r/rw
methods
what u need is a dvd to vcd guide.....try the dvdrip section -
The problem I have is, I've downloaded a few dvd films from the internet and I want to put them onto VCD discs because I want to watch it thru my DVD player (big screen) instead of playing it thru the computer, is that dvd section gonna help?
I have been trying to do the same thing. From my experience (which is limited to say the least) I would say, you will not be happy with VCD. I found the quality to be unacceptable (to me). If you are on a big screen TV, I suspect it will be even worse than my 36 inch TV.
I have been burning to SVCD. The quality is great. Expect to use 2 CDs per movie at a minimum. I have learned a lot from reading the newbie guides on this site (GREAT Site !!!!). I still have a lot to learn but I am working on it.
Good luck! -
I've just been told about this site, so I'll have a good look round it and try to figure it out. -
ive been making vcd's for a few months now thanks to this site and its guides. i find that making xvcd's, a 2 hour film using the 1 disc template is great even better quality if you split the film into 2 discs, somewhere in between vcd and svcd. if you p.m. me ill tell you how i do it
Splitting bluray movie to 2 bd-r discs
By jayt34 in forum Authoring (Blu-ray)Replies: 4Last Post: 25th Jul 2010, 19:50 -
Who to put subs in film ?
By dimbadboy in forum SubtitleReplies: 2Last Post: 4th Dec 2009, 08:55 -
Help with Ripping audio from a VCD (2 discs) to put 1 DVD for a movie.
By shuya_nanahara in forum Newbie / General discussionsReplies: 7Last Post: 24th Jan 2009, 23:40 -
Splitting episode dvd to 2 discs
By parman in forum EditingReplies: 3Last Post: 12th Sep 2007, 17:05 -
I need help with splitting 21 video files on two discs.
By ombin in forum EditingReplies: 1Last Post: 19th Jul 2007, 22:02
