My Pioneer DV-444 has troubles playing back CERTAIN svcds. Mostly svcds that are on 2 discs. It has something to do with teh bitrate being under 1200 and than mpeg anomalies and freezeframes start to occur. I have tried every medium and every speed setting so that's not teh problem, they also work fine on my friends 535.
Nos I was wondering if anyone happens to know whether these problems have been solved by the DV-454? And does the dv-444 outperform the 454 when playing back regular dvd's?
Thanks for the help!
LG LRH-780 DVD Drive Problems..... Solved!
By dragon064 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 4th Feb 2010, 20:59 -
[solved]Problems about transitions in DLP
By ihmcjacky in forum Authoring (DVD)Replies: 5Last Post: 3rd Feb 2009, 00:07 -
[SOLVED] Problems running dvdrebuilder in wine
By freebird73717 in forum LinuxReplies: 3Last Post: 10th Mar 2008, 13:44 -
SubtitleCreator Problems (Solved)
By TRUSTpunk in forum SubtitleReplies: 9Last Post: 8th Aug 2007, 13:05 -
Pioneer DVD DV-393 Progessive Scan Locked - Problem Solved
By kbm in forum DVD RippingReplies: 2Last Post: 27th May 2007, 18:52
