    Aug 2002
    Saint Etienne - FRANCE
    Hi,
    I posted a few weeks ago about framerate conversion. Is it possible with a mac ?
    I have 3 movies with à 23,98 framerate.
    I want to make VCD PAL (25 FPS).
    Quicktime works but movie are jerky (there are short pauses every second).
    What can i use ?
  2. you can use mediapipe, but you need to be running osx
  3. If you are looking to purchase:
    DVD Film Transformer (trial version): http://homepage.mac.com/DVD_SP_Helper/Commerical/DFT.html
    It can go from PAL->NTSC and NTSC->PAL. It works as a quictime export component.
    Aug 2002
    Ok, i'm going to try.
    Thank you.
    7th layer of hell
    dvd film transformer is a pile of crap... the only way it is useful is if your input file is quicktime and u want to convert to quicktime again, it chokes an mpeg 2 input and doesnt export direct to mpeg-2 either, i cant believe the authors want 125$ for the suite of applications.. total rip off, dont waste your time. stick w/ mediapipe, not only is it FREE its ALOT better.
