hello all!!
This is my question: Does a movie that is on 699mb fit on a 700mb disc, if the movie is 1 hour and 28 seconds long?? I hope it does , i dont think it does, but i need answers! bye bye :)
"Itīs dangerous to live, you can die"
What software are you using to burn.
you should be able to put it on a disc just select overburn disc in your software if it says its too big. -
A 699 MB avi will fit, and you can usually go a few MB above with overburn. If it is (S)VCD mpeg, then ~790MB will fit. 8) The length of the movie is not a factor for avi or SVCD. For VCD ~ 80 minutes corresponds to 790MB.
Thank you very much!!
I think that the format on the film is avi, but iīm not sure. Iīll check it out. Thanks again"Itīs dangerous to live, you can die" -
Hi again.. One more thing.. With the VCD-guide with Nero, that I found here and which is good. It says that i have to add mpges to the disc, not avi. But, can I add avi too? Wonīt there be a problem?.....
I hope that you get my question....
If you start with a VCD-compliant mpeg, you can burn to VCD with Nero. If you try the same process with an avi, Nero will attempt to encode it first before burning to VCD. Not only will this be a lengthy process, but the result will be inferior to using TMPG.
In order to burn a vcd you must have a compliant mpeg1 movie file.
an avi will not work for vcd. you must convert the avi to mpeg1 format and then burn the mpeg to disc using vcd in nero
Trying to edit a movie on windows movie maker (Canon Vixia HF R20)
By Classic in forum EditingReplies: 1Last Post: 8th Mar 2012, 13:07 -
compare movies, find insertions in one movie relative to another movie
By beroal in forum Newbie / General discussionsReplies: 0Last Post: 19th Jan 2012, 00:11 -
Whats the diffrence between AC3 Blu-ray movie and a x264 movie?
By evdeneale in forum Newbie / General discussionsReplies: 1Last Post: 21st May 2011, 00:16 -
Windows Movie Maker crashes and won't puplish whole movie
By LoveMyslf in forum Video ConversionReplies: 27Last Post: 12th Dec 2009, 23:19 -
Resident Evil First movie ...Not Apocalypse the 2nd movie backup issue!!!
By vanc in forum DVD RippingReplies: 0Last Post: 19th Oct 2007, 12:33
![Send a message via AIM to [ShaRk]](images/misc/im_aim.gif)
![Send a message via MSN to [ShaRk]](images/misc/im_msn.gif)
![Send a message via Yahoo to [ShaRk]](images/misc/im_yahoo.gif)
