Hi. I burn anime episodes onto DVD and so far I've managed to fit seven onto one disc. I think I can bump it up to about eight or nine so I can fit an entire 26 episode series onto one disc, but I need a bit of help.
What I wanted to do was cut off the opening and ending of each episode (it's the same thing each time anyway) and put the following files onto the DVD
1. Opening Credits
2. Ending Credits
3. Anime episodes
I figure I can shave off a good two or three minutes from each episode, letting me pop on at least one extra episode onto each DVD.
What I want to do is make it so the DVD will play that one opening credit before each episode on the disc, and then have it lead into that individual episode. Can I do something like that with ReelDVD?
Look at a program called Vobedit. It will extract a vob file into it's cell's. You can look at the cells and see which ones you want to eliminate. Then remerge what you want to keep into one vob.
I don't know about ReelDVD, but I imagine that it can, since all programs that I'm using (Scenarist, DVDMaestro, Spruceup, DVDit-PE) can all do this with no problem.
DVD authoring question...
By mjl1297 in forum Authoring (DVD)Replies: 8Last Post: 12th Mar 2011, 10:26 -
dvd authoring speed question
By slaak in forum Authoring (DVD)Replies: 0Last Post: 25th Jan 2009, 13:14 -
dvd authoring question
By ht0160 in forum Authoring (DVD)Replies: 1Last Post: 7th Jul 2008, 16:52 -
Another DVD Re-authoring Question
By videopoo in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 02:40 -
New to dvd capturing/authoring… Question
By tygger in forum Authoring (DVD)Replies: 7Last Post: 18th Jun 2007, 13:17
