Hi.
I need help with Gordian Knot.Everytime I shall make an .avi file from GK it ends up with one file that is 150 MB.But the file should be around 700MB.
The dvd i use is PAL and it's 1:19 long.I don't know what I do wrong,so please help me.
First I ripp the dvd,then make an .asv file with DVD2AVI and then try to encode with GK,and everytime end upp with an file that is 150 MB.
Please help
I follow your method partway, but with DVD2AVI I produce a wav and a d2v file. I read the d2v file back into GK, do any cropping and resizing, and output an .avs file. At this stage I use Virtualdub directly to encode, using the bitrate suggested by GK. This works brilliantly, and I can usually encode to with a few MB of my target size.
The critical difference, I think, is I use *save* rather than *save and encode*. -
in DVD2AVI select "Save Project", this will give you a d2v file (video) and a wav file (audio) then put these files in TMPGEnc
DVD to VCD made eazy
http://www.eazyvcd.tk -
This is good advice for encoding mpegs, but not so good for encoding avi. I know TMPG can encode to avi, but I have yet to work out how to get it to do 2-pass. If you know, please tell me. 8)in DVD2AVI select "Save Project", this will give you a d2v file (video) and a wav file (audio) then put these files in TMPGEnc
Problem with Gordian Knot
By eliqush in forum Video ConversionReplies: 3Last Post: 7th Jul 2009, 19:35 -
Gordian Knot - No subtitles
By gustav32 in forum DVD RippingReplies: 1Last Post: 18th Jun 2009, 05:44 -
What's the best filter to use in Gordian Knot?
By ltd. in forum Video ConversionReplies: 1Last Post: 5th Jan 2009, 13:22 -
using Gordian Knot
By ricmetal in forum Video ConversionReplies: 3Last Post: 6th Dec 2007, 14:20 -
Gordian Knot help
By zookeeper525 in forum DVD RippingReplies: 25Last Post: 16th Aug 2007, 00:49
