hey all-I'm a newbie here, just got my dvd player on the weekend.
I have 2 questions.
1 have some moveis in .avi format I'm looking to burn as vcd's.
my questions are:
1) is it best to cut the files to fit on multiple discs BEFORE converting from .avi to mpeg using TMPGEnc, or after?
I'm thinking before is the correct answer...but I dunno...
2) what's the best bitrate to use? Can it be too high, or should I just select a high # like 2500 or something??
thanx!!
Cut the files while they are in Virtual Dub. Then frameserve to TMPGEnc, using the appropiate template. If you have blocky video, try the soften block noise to raise your frame rate.
Hello. -
If you want to make standard compliant VCD's the bitrate is set at 1150kbps.
Craig -
What if they're not movies I'm ripping, and therefore not using Virtualdub, I just have an .avi file.
thanx for helping out a newbie!
Originally Posted by Tommyknocker -
Originally Posted by jr!What every YOU prefer !, you could also use the source range in TMPGEnc on the full size movie AVI's1) is it best to cut the files to fit on multiple discs BEFORE converting from .avi to mpeg using TMPGEnc, or after?
Yes select 2500 or something, but it wont be a VCD2) what's the best bitrate to use? Can it be too high, or should I just select a high # like 2500 or something??
and it "Might not play"
Use a VCD template in TMPGENc and change nothing
A few questions about bitrate,codecs and virtualdub
By alibaba12 in forum Newbie / General discussionsReplies: 21Last Post: 5th Jan 2012, 18:30 -
Newbie questions on saving, converting, burning, etc..
By osb_tensor in forum Newbie / General discussionsReplies: 2Last Post: 1st Feb 2010, 23:42 -
Some (not newbie) questions about video importing/converting/deinterlacing
By F_Krisztian in forum Newbie / General discussionsReplies: 5Last Post: 18th Sep 2008, 07:07 -
Newbie questions on converting avi to mpeg2 and dvd authoring
By mlcampbe in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2008, 14:08 -
Questions about video resolution, and bitrate
By jay_lubb in forum Newbie / General discussionsReplies: 3Last Post: 18th Sep 2007, 15:46
