Hi,
I want to make a presentation to a software.
I want to capture the computer screen when I'm working with the software...like a demo.
I use 2 computers.
One have a Marvel G450 eTV for capturing.
The other (where I run the software ) have a Trident 3d Image9850 with TV out.
I can capture, but the problem is that the quality is very very very BAD.
What I see on the monitor, in the PC-VCR window...and after I capture is very bad quality.
What should be the cause ?
The second graphic ( trident ) is the reason ?
Thanx
Hi,
I tried with HyperCam...and the results are OK...just that I cannot capture the sound in the same time...it jumps...doesnt' capture continuous sound...
The maximum frames per second is about 5, but maybe is because I have a trial version..dunno
I will try snagit...
Thanx -
go to www.techsmith.com and get a demo of camtasia...it does everything you can think of.
There's a program from Lotus called Screencam. That's very nice, as it produces very small exe-files instead of avis.
Jesus:"If any one of you is without sin, let him be the first to throw a stone at her!"
*flyingstone*
Jesus:"Mother, quit bugging me!"
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 07:17 -
Problem using HDTV for computer screen
By beavs in forum DVB / IPTVReplies: 34Last Post: 17th Sep 2008, 01:07 -
Video Computer Screen Capturing
By foochuck in forum Newbie / General discussionsReplies: 4Last Post: 9th Apr 2008, 08:20 -
My computer's screen to DVD Recorder
By mingul in forum Capturing and VCRReplies: 16Last Post: 16th Nov 2007, 01:39 -
Screen Computer Captures
By Steverup in forum Capturing and VCRReplies: 4Last Post: 5th Jul 2007, 22:02
