I've ripped 'The One' to SVCD and multiplexed the video and audio.
All is good there.
When it comes to cutting the file to fit onto 2 cd's is when the problems start.
I use the Mpeg Tools from Tmpeg to select the first half and
it cuts, demuxes and remuxes the new file to give me
the first half of the movie.
When I go to do the second half it demuxes the video, demuxes the
audio and then locks up.
I've tried rebooting and doing the second cut again but always the
same result, demux video, demux audio lock up.
Any ideas anyone?
Waylander
Yo hi,
try to demultiplex your files with TMPGEnc (simple demultiplex does it). After that, take bbMPEG and multiplex your files again. Specify the maximum size before you start your conversion.
Take a look into the how-to section how to cut, join with bbMPEG. There is a great guide how it works.
TMPGEnc has mor often Problems by cutting SVCD Streams.
Greetz
Jam_Bo -
I've found when cutting using TMPGEnc that at a certain stage it does appear to lock up or be doing nothing but it is actually still working away.
Try leaving it for a while and see what happens. It should be ok. A watched pot never boils and all that.
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 19:45 -
Simple MPEG2 Cutting/Joining Question
By thefiddler in forum EditingReplies: 4Last Post: 21st Dec 2009, 16:39 -
WinDV sync problems (Update: never mind, it's a TMPEGEnc problem)
By timmus in forum Capturing and VCRReplies: 0Last Post: 6th May 2009, 15:39 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 02:12 -
[solved] Major MPEG2 Cutting issues. Looking for program that will work.
By ShadowBlink in forum EditingReplies: 17Last Post: 17th May 2007, 20:55
